I'm sorry folks, this list started as an easy-to-read MS Word table but it would not cut-n-paste into this message and I cannot attach a document, so I had to resort to a simple, sequential list. Hopefully this will provide some useful info? If any of you find mistakes, I reserve the right to make corrections... I will add applicable info or additional approvals when available.
Respectfully,
Les Doud
Hartzell Propeller Inc.
[email protected]
Blades: 7666A-2, -4
Engine: Lyc O-360-A1A
Crank: 180 Hp w/o dampers
Compression Ratio: 8.5:1
Ignition: Std. Mags.
Placards: Avoid continuous ops 2000-2250 RPM
Diameter: 74-72?
Blades: 7666A-2, ?4
Ignition: One Lightspeed, one mag
Placards: - Avoid continuous ops 2000-2250 RPM
- Ops above 2600 RPM limited to takeoff only
- Propeller blades are life-limited to 8700 hrs.
Diameter: 74-72?
Blades: 7666A-2, -4
Engine: Superior O/IO-360-B1A2
Ignition: Std. Mags
Placards: - Continuous ops prohibited above 20? MP between 1950-2300 RPM
Diameter: 74-72?
Blades: ?BA? 7496, -2
Ignition: Std. Mags
Placards: Continuous ops prohibited above 22? MP between 2050-2200 RPM
Diameter: 74-71?
Ignition: Std. Mags and/or Lightspeed or Unison LASAR
Placards: - Do not operate above 22? MP below 2350 RPM
Diameter: 74-72?
Blades: ?BA? 7496, ?2
Engine: Lyc IOF-360-A1A
Ignition: Aerosance FADEC
- Maximum (red line) RPM limited to 2650 RPM
Diameter: 74-72?
Blades: ?BA? 7497, -2
Engine: Lyc IO-360-A1A
Crank: 200 Hp w/o dampers
Compression Ratio: 8.7:1
Ignition: Std. Mags
Placards: Continuous ops prohibited above 24? MP between 2350-2550 RPM.
Diameter: 74-72?
Engine: Lyc IO-360-A1B6
Crank: 200 Hp w/ dampers
Ignition: Std. Mags
Placards: None
Diameter: 74-72?
Engine: Lyc IO-390-X
Ignition: Std. Mags
Placards: None
Diameter: 74-72?
Van?s only endorses the 74? propeller for RV-4s with long gear legs and the RV-6/6A, 7/7A and 8/8A.
NOTE: Propeller vibration characteristics and stress amplitudes on a reciprocating engine installation are primarily mechanically generated by the engine. Any modification to the standard engine configuration to include high-compression pistons, electronic ignition, FADEC, tuned induction and exhaust, and turbo-charging or turbo-normalizing have the potential to adversely affect the propeller vibration characteristics and stress amplitudes. Hartzell Propeller therefore does not endorse any such engine modification unless the specific engine and propeller configurations have been tested and found to be vibrationally acceptable according to 14 CFR 23.907.
Respectfully,
Les Doud
[email protected]
Blades: 7666A-2, -4
Diameter: 74-72?
Blades: 7666A-2, ?4
Diameter: 74-72?
Blades: 7666A-2, -4
Ignition: Std. Mags
Diameter: 74-72?
Ignition: Std. Mags
Diameter: 74-71?
Diameter: 74-72?
Diameter: 74-72?
Ignition: Std. Mags
Diameter: 74-72?
Ignition: Std. Mags
Placards: None
Diameter: 74-72?
Ignition: Std. Mags
Placards: None
Diameter: 74-72?
