I receive the Hartzell S-1-32 prop governor from Vans with my IO 540 fire wall forward kit and it is not working with my MTV-12-B/193-53 propeller. Sent Prop and governor to Prop shop and both are working according to them. Put them on engine and nothing. No prop accusation. No, I did not leave the plug in on the engine or the propeller. I had a local A&P mechanic (who has started hundreds of engines) look at the installation and we are scratching our heads. The only way to get anything out the the Governor is to pull it to full back position and the prop will not overspeed. Any thing other that this and it does not accurate the propellor. Vans says both the Hartzell and the MT governor's will work. Any one have this issue and if so what an I doing wrong....
