I wonder if anyone has a solution to this issue. I have a hartzel HC-C3YR-1N/N7605 prop on my RV10 and when reinstalling after replacing the alternator belt one of the wire keepers that goes through the bolt broke allowing the nut to rotate on the bolt.
To be clear I don’t know what to call the open shaft that passes through the head of the nut to allow the safety wire to pass through. I also assume it it keeps the head of the bolt(nut) on the bolt shaft.
Is there a way to replace these keepers?
Thanks for any help.
