Hi Everyone
I have an RV4 with an O360 180hp motor and a new 72 inch Hartzell BA prop from Vans (PROP C2YR-1BFP/F74972).
The only restriction I can find on this prop is the following:
Restrictions:
The following restrictions apply to the HC-M2YR-1BFP/F7497 propeller on the RV aircraft with Lycoming IO-360-A1A 200 HP engine: ?Continuous operations is prohibited above 24 inches manifold pressure between 2350 and 2550 rpm.?
I know this might be a stupid question in this case but I often get conflicting stories, so due to the fact that I only have an O360 and not an IO360, I will therefor have no restrictions on my engine/prop combo?
Thank you
Restrictions:
Thank you
