I'm looking at the manual for my Lightspeed electronic ignition, for reisntalling and clocking my Hall Effect Sensor module. The manual says:
Question - Should this procedure be done with the ignition keyswitch in the OFF position or in the R position (ignition module being installed on Right side)?"...Turn electrical power on and rotate the sensor module in the accessory case counter-clockwise until the green light on the module case turns on and then off again. Maintaining its position, fasten the sensor module with the toe clamps..."
