eavila1
Member
Good morning all. So I powered up my Garmin suite and my GTN 625, ADHRS, G5, G3X Screen, 507, and GTR200B all powered up and all communicating without issue on the Can Bus. All show green checkmarks in the Configuration page for the G3X. Then I checked the 200B to see if i was receiving on incoming calls at my airport SJN. But Nada. So out comes the installation manual and I ran through the setup and headset checks. Made sure antenna was connected, but its loose and not bolted down yet under the 9. The comm shows a transmit X when the copilot panel PTT switch is pushed. I can hear a tone in the headset on the left but none in the right and there is a checkmark on the right headset during the test check. Manual says its because either the headset is mono or there is a wiring problem. Intercom appears to work in the headset but still not receiving incoming transmissions or ASOS etc. I can hear the squelch in the pilot/copilot headsets, so I don't think it is my jack wiring.
Any ideas?. Anybody have the same issue? I'm thinking maybe its a setting that I'm missing. When wiring my headset jacks I must have verified 20 times that the wiring was correct. ??
No error messages on 200B screen
