B bob888 Well Known Member Sponsor Nov 29, 2015 #1 Does the GPS antenna (Garmin) require a ground plane? Specifically, can it be mounted to the fiberglass cabin top without building a ground plane under it?
Carl Froehlich Well Known Member Patron Nov 29, 2015 #2 The GPS antenna needs no additional ground plane. Carl
awmuhs Well Known Member Nov 30, 2015 #3 gps antenna I have my garmin and Dynon gps antennas mounted about 8 inches apart on the fiberglass cabin top. They work great.
