Good pics of vetterman install on io-360 / 7-A
nohoflyer
Patron
Vetterman instructions are less than ideal. I started placing pipes in approx locations and it left a lot to seemingly technique. I would really appreciate any good pics of an installed system from a few angles. The only graphics vettermans includes are poor sketches imo.
Hope this helps.
These are great. Thank you. Were there any other linkages you used to secure the back of the system to your weldemnet?
I was not addressed, but just in case.
I have several photos of the hangars. Send a PM or e-mail.
Wirejock at yahoo dot com
I wouldn’t mind seeing the way you did the hangars as well. I’m still a little confused how these brackets are supposed to work. They are different to the plans.
I think they get a linkage back to the sump, and another to the engine mount. Not certain tbh! Here is an example I found somewhere.
Mine is an angle valve 360 for a -14 but I’ve gone the split pipes to match the EXP-119 cowl. I think this is the same design as the -7 except 460mm centres (further apart?)
This is the best pic I have. I did end up putting a piece of rubber hose over the engine mount, to protect it from the rubbing.
