tdavis1198
Active Member
I have an RV-8 (approx 100 hrs). Not the original builder. If you look at the video you will see the left gear leg oscillate forward and backward just prior and after the wheels leave the ground. In the video, I kept the nose forward to accelerate as much as I can. Its definitely speed related.
Since this problem began we have re-torqued the gear attach bolts, repacked the bearings and check the brakes. The gear is the Grove Aerofoil gear, wheels and brakes are standard Matco.
Any recommendations?
https://drive.google.com/file/d/1LwuG92UpQP5eYXgSdqoOLRiS5KHE-XZ_/view?usp=sharing
