I’m finishing up a complete G3x install on my RV10 and I’m having a problem getting my gtx 33es to talk properly to my G3x or gtn625. I’ve wired the transponder per the diagram in the G3x touch manual page 27-30. Ive setup the rs232 #1 connection going out of the gtn625 to the gtx 33es rs232 #2 as “adsb+Format 1”.
Ive got the gtx 33es rs232 #1 going to the gsu25 rs232 #3.
On the gdu 460 transponder config more page I set the transponder type to gtx 33es. I also have gone through the complete transponder configuration including position integrity set to 1E-7.
Unfortunately in my gdu 460 configurator I see no place to set the gtx33es rs232 Input format to remote and the rs232 output to remote+tis.
On the gdu460 under the transponder config the system has a green check mark but says “waiting for data”.
I see on page 27-37 of the G3x touch installation manual that the transponder is wired completely differently then the way the manual shows it being wired on page 27-30.
Another question I had is On page 27-30 it shows the gtx33es rs232 #2 signal ground as pin #50. The gtx33es manual I’m using shows pin 50 as a altitude ground? The manual shows the serial grounds as pins 51 & 58. So I wired my serial ground to pin 58 which page 27-37 shows as correct?
Lastly ive installed a gdl 50r and wired the 2 rs232 connections to my pfd and mfd respectively. I’ve configured the respected gdu 460 pfd and mfd rs232 connection and confirmed they are talking with a check mark on each display connected rs232. In the G3x touch manual it states there should be a selection in the gdu460 configurator for “data link configurator” only when a gdl is connected. I have this selection but the only thing it shows me when I open it is “mode s address”. Nothing about aircraft type, adsb traffic data, or mode s address type.
All my systems have the most updated software except possibly the gtx 33es as I bought that second hand and since I can’t get it to talk properly yet I’m unable to see what software it’s set to as it blank on the screen even though the system shows it wit a green check mark.
Thanks for any guidance you can assist me with.
Bill
Bill
