Hello Everyone, who is thinking about installing one of the above units, or the GNC 355, here is what I have learned installing the above units over the last few days.
Settings in the Garmin are,
ARINC
RX EFIS/ADC, HIGH
TX GAMA Format 3, HIGH
RS232
Aviation Output 1. Note: On the 375, the only RS 232 ports with Aviation Output 1 are 1 & 2. On the 175, all three ports have Aviation Output 1.
On the 175 install, we connected it to a SkyView Classic Touch using the ARINC 429 module, but it would work the same way on the HDX screens.
On the 375 install, we connected it to a Dynon D-100 without using the HS34 module, but he only has lateral tracking only using his autopilot until he upgrades to the SkyView HDX next year. We used Serial Port 1 set to Aviation 1 for Autopilot commands and Serial Port 5 RX set to Alt Frmt 1 100FT for his pressure altitude from the D-100. Set the RS232 output from the D-100 to Format 4.
Brian
ARINC
RX EFIS/ADC, HIGH
RS232
Brian
