So we have recently completed our RV 10. Busy with proving flights. We have a G3X installed.
I have found the mechanism to alert Flap overspend, which uses Invisible points. These logical measures are super, but on approach Mavis pipes up constantly Terrain, terrain, pull up,pull up.
This is most distracting, I know I am going to land as I have extended Flap and airspeed is low. Is there any way to use the same logical points to switch off the voice alerts if the flaps have been deployed.
I cannot seem to be able to find the correct place.
Otherwise I will consider disable the voice alerts alerts completely, because it is so distracting.
