For those of you that might have these boxes are 2 sets of 2 Serial in/out ports required and connected to your Sport EFIS or just one set? The 650 pins I am referring to are pins 8 & 27 of P1001 and referred to as Rs232 out1 and in1 respectively; and pins 7 & 26 of P1001 and referred to as Rs232 out2 and in2.
GRT documentation makes no mention of this second serial port from the 650 and if it's needed I'm not sure where to wire it in unless I run it thru the serial combiner. Can't get a hold of any tech at GRT! I also have the ARINC box and the Mini-X but I'm pretty clear on the wiring of these.
Jim
RV9a
Jim
RV9a
