So I'm doing my schematics for my G3X and I'm trying to understand the attached diagram of the GAD 27/Flap wiring.
In my old RV 6, I had a momentary ((ON) OFF (ON)) switch for the flaps. You would just hold the switch in the direction you wanted the flaps to go and when actuator reached the limit, it just spun until you released the switch. Simple enough, or if you wanted 1/2 flap you just let go the switch right about "there", although I almost never used anything but full. Maybe the RV 8 needs 1/2 flaps for the "tail low" wheel landings I've heard so much about?
Anyway, looking at the G3X GAD 27 diagram it seems like they want me to use a 3 position switch ( ON,ON,ON). OK, but if you want a mid position, you kinda have to be careful about switch placement when moving it. OK, so be it.
I'm planning on using the stock flap motor that was supplied with my 2018 kit. I know there is a new style, larger motor with internal feedback positioning, but I already have the stock flap motor mounted and a nice cover for it, and a MAC position indicator for the GEA 24.....and I'm cheap.
Two questions I have are:
1. The diagram shows limit switches at the up and down position. I guess that it's necessary or the GAD 27 will keep running the flap motor if it doesn't get a "home" position. My guess is it probably will.
2. Even using the MAC position sensor wired to GEA 24, how does the GAD 27 know where the "1/2 Flap" position is? I don't see any communication between the GAD 27 and the GEA 24 to tell it where it is.
What I'm I missing?
Is it all just for the convenience of touching the switch once and forgetting about it? Just me but I'm not sure it's worth all that.
I'm considering not wiring the flaps to the GAD 27 and going my old RV 6 "simple" method that worked for 2000 hrs. Seems simpler. I really like looking out the window to verify the flap position and don't need to see it on the screen.....probably take me longer to find it on the screen rather than just looking anyway.
Can someone shed light why the GAD seems so much more complicated (to me)?
Thanks for the help,
Laird
SoCal
What I'm I missing?
Laird
SoCal
