I had the same question. SteinAir (Dave Holtorf) wired my panel and he provided a small wire (shielded) labeled "main voltage". Here is where Christer told me to hook it in to the system.
"The main volts can be connected to the main buss or alternatively the
output of the main contractor. Electrically they are the same. It should be
connected with a 1 amp inline fuse to protect the wire."
There are several connections what require that 1 amp fuse inline on the firewall. I really don't like these as they are hard to access, don't lend themselves to tidy installation, and introduce a mechanical connection in that electrical path. I will be using blade fuses as they have better contact than the cartridge type.
I hope this helps.
