G3X Touch SW v9.41 Available Now (5/13/2024)
With Version 9.41
1 first point :
I can display only 2 fuel tanks (I have 4)
Second point:
When we display Engine tabs, I have 2 tabs (Main, Fuel calculator)
After clic on Fuel Calculator, I have 3 tabs (Main, Electrical, Fuel Calc)
After clic on Electrical, I have 2 tabs ( Main (empty), Fuel Calculator)
View attachment 64174View attachment 64175View attachment 64176
Can you please export a configuration file and email it to us at [email protected]?
Justin
With Version 9.41
1 first point :
Second point:
I had very similar result due to a bad connection on the roll servo CAN-BUS pin. Might have nothing to do with the sw upgrade.
J'ai eu un résultat très similaire en raison d'une mauvaise connexion sur la broche CAN-BUS du servo roll. Cela n'a peut-être rien à voir avec la mise à niveau SW.
Today, it's on my table, with only GE24 connected, I have not this issue before V9.41
Good Afternoon,
G3X Touch software version 9.41 was posted to the Software Download Area today. Among several background improvements there are a few new features included, as detailed below. A new Installation Manual, revision AV is also available, which is necessary to make use of several of the changes included in this update.
  • Support Traffic and Terrain Inhibit Discrete Input
    • Two new discrete input presets are available, Terrain Alert Inhibit and Traffic Alert Inhibit. These are alternate means to inhibiting these alerts, the other being through the display.
    • Along with these inputs, 3 new CAS Messages were added to the system:
      • TERR INHIBIT – Terrain Alerts Inhibited
      • TA INHIBIT – Traffic Alerts Inhibited
      • TRFC FAIL – Traffic device or traffic input failed
  • Configurable Flap Position Threshold for AOA
    • In the initial dual curve AOA calibration implementation, when two AOA curves were calibrated (one for flaps up, one for flaps down), the system would switch between the two based on value that corresponded to roughly 50% of the flap position sensor range ( ~50% deployed).
    • This change allows the installer to move that 50% value, and effectively control when the system switches from one curve to the other. A value of 30 would correspond to a switch at 30% flaps deployed, so it would switch curves sooner than before.
  • Allow Alternate Orientations for Charts
    • Sectional charts can now be displayed in alternate orientations, previously limited to "North Up" only.
  • Added User Settings for Flight Log Recording Mode
    • Flight log can be set to record normally (airborne or when engine is running), airborne time only, or disabled entirely.
  • Added User Preference for Vertical Engine Bar Width
    • If the vertical engine bar is not being forced to use the wide width to accommodate the configured contents (e.g. multi-engine gauges) the "EIS Layout Size" option will give the user the option to select the size of the vertical engine bar on each display. Allowed options are Narrow, Wide, and Auto. Auto will use the wide layout if any text-only gauges are configured.
    • This can be set to Auto or User selected in the Display Menu in Configuration Mode. If set to User selected, there is a pilot-side setting for this in the Display Setup menu in normal mode.
  • Added Discrete Functions to Toggle Audio Panel ICS Isolate Modes
    • 2 new presets are available for discrete inputs, relating to ICS Isolation modes. These remotely toggle the active state of either pilot or crew isolate modes for GMA 245(R)(M) audio panels.
  • Added Configuration Setting to Enable/Disable Spoken CAS Alert Audio
    • Spoken CAS Alert Audio can now be disabled in the Sound Menu in Configuration mode, using the Engine/Airframe Alert Mode Setting.
  • Vertical Power Improvements
    • Vertical Power Amps and Volts are now configured through a dedicated Vertical Power tab, within the Engine & Airframe Menu.
    • Trim and flap position, if configured and calibrated on the VPX, will be shown on the page as well. This allows the installer to configure gauge ranges for these, and ultimately make use of logic signals for VPX derived sensor inputs.
  • Expand Temperature and Pressure Preset Options
    • CHT 5 & 6 now double as Temp 3 & 4, and can support all types of temperature sensors.
    • EGT 5 & 6 now double as Temp 5 & 6, and can support thermocouples but not resistive sensors.
  • Modify Logic Signal Behavior
    • With this change, any signal which is not configured to be set by any parameter will now automatically set itself. This removes the need to create a "fake gauge range" to achieve certain kinds of alerting behavior where the desire is to have a logic signal whose state is solely driven by airspeed or altitude. The net change for this improvement is that some alerting and gauge marking behaviors can be accomplished more simply.
  • Show Decoded VLOC Identifier on HSI
    • When a VHF NAV CDI is selected, the NAV Frequency will be displayed within the HSI. When decoded VLOC identifier is present, it will switch to the identifier.
  • Traffic Conflict Alerts
    • Audio alerts for traffic conflicts are now inhibited below 300AGL
  • Rotax 916iS Support
    • The Rotax FADEC setting which can be applied to various engine sensor presets is now compatible with data provided from a 916iS
Several system LRU's will be updated with this software load, the software download page includes a detailed LRU software change list. Cross-referencing the System Information page in configuration mode, please ensure each LRU is successfully updated to the appropriate software level upon completion of the software load.
  • Added configuration of CAS message audio alerts
  • Added ability for VFR/IFR chart orientation to follow map page setting
  • Added ability to display VFR/IFR chart inset on GDU 46x PFD
  • Added display of VLOC frequency or decoded NAVAID identifier to HSI
  • Added support for additional temperature and pressure sensors
  • Added support for custom range markings for Vertical Power EIS gauges
  • Added user setting for engine bar width on GDU 46x
  • Added support for GSU 25 zero-airspeed calibration procedure
  • Added support for RS-232 connection to GTR 205 / GNC 215
  • Added support for Rotax 916iS FADEC data
  • Added optional configuration of flap position threshold for AOA alerting
  • Added inhibit settings for AOA and radar height audio alerts to sound setup page
  • Added setup pages for terrain and traffic settings
  • Added ability to inhibit terrain or traffic alerts via discrete input
  • Added ability for EIS logic signals to set themselves when not set explicitly
  • Added user setting for flight log recording mode
  • Moved inhibit settings for AOA and radar height audio alerts to sound setup page
  • Moved fuel calculator configuration to separate config mode page
  • Improved GTX 33 configuration
  • Improved radar height audio annunciation
  • Improved Smart Glide annunciation in areas of changing elevation
  • Improved traffic audio alerting at low altitudes
  • Improved takeoff altitude audio alert
  • Improved Rotax SCU fuel pressure display
  • Improved lean assist configuration for aircraft using TIT
  • Improved organization of display configuration page
  • Improved GSU 25C/D static pressure calibration
  • Improved EIS gauge display and layout
  • Improved fuel-used recording when power is removed
  • Improved engine cycle count recording
  • Improved checklist file processing
  • Improved audio alert output
  • Improved data logging
  • General improvements to system operation
  • Includes update to G5 software version 8.51
  • Includes update to GEA24(B) software version 4.00
  • Includes update to GMA245 software version 3.20
  • Includes update to GSU25/B/C/D software version 4.50
  • Includes GSU25/B boot block software version 2.30
  • Includes GSU25C/D boot block software version 2.10
  • Includes GMA245 audio software version 2.20
  • Includes GMA245 Bluetooth software version 2.00
  • Includes GMA245 boot block software version 2.40
  • Includes GEA24B boot block software version 2.00
  • Includes GEA24 boot block software version 2.20
  • Includes GHA 15 boot block software version 2.00
  • Includes GHA 15 software version 2.00
  • Includes G5 boot block software version 2.40
  • Includes GAD 27 -1X software version 2.00
  • Includes GAD 27 -1X boot block software version 2.00
  • Includes GAD27 boot block software version 2.30
  • Includes GAD27 software version 2.80
  • Includes GAD29 software version 3.40
  • Includes GAD29 boot block software version 3.10
  • Includes GAD29C boot block software version 2.00
  • Includes GAD29C software version 2.10
  • Includes GSU73 software version 3.80
  • Includes GSU73 IGRF database version 1.04 (Base Year 2020)
  • Includes GAD13 software version 2.10
  • Includes GAD13 boot block software version 2.00
  • Includes GDL39 software version 4.91
  • Includes GI260 software version 2.90
  • Includes GI260 boot block software version 2.20
  • Includes GMC507 software version 5.00
  • Includes GMC507 boot block software version 2.30
  • Includes GMU11 software version 2.20
  • Includes GMU11 boot block software version 2.10
  • Includes GPS20A software version 2.40
  • Includes GPS20A boot block software version 2.10
  • Includes GSA28 software version 5.70
  • Includes GSA28 boot block software version 2.20 or 2.10 (-2X Model)
  • Includes GTR20/200 software version 3.50
  • Includes GTR20/200 boot block software version 2.40
  • Includes GDL5x software version 2.23
  • Includes Timezone database version 37.00
Please let us know what questions you have!
Justin
Hi Justin --- I upgraded my G3X system to 9.41 from 8.81. The vertical mode of my autopilot no longer works ----- when the autopilot is on and is in ALTS armed mode things appear to work, however when it gets to 200 feet below the target altitude the autopilot commands a full NOSE DOWN. In addition, the vertical mode side of the scoreboard displays information that makes no sense ---- it displays ALTS (in white) when no altitude has been selected and no vertical mode is selected.
I don't understand why these kinds of things happen ------ what do you suggest?
David
N797EJ
Justin
Hi Justin,
I found a case where the bug arrives and it disappears:
on display setup, if pass "EIS/ENGINE Page Layout" to Separate -> I have the display bug on engine Tab like I discrib before
David
N797EJ
David,
Can you please send us the flight data log from your SD card?
Justin
Anyone seen this bug ("feature") with 9.41? In the past, when I had an approach loaded in my GPS175, It would automatically come up when I clicked over to the flight plan page and touched the "charts" button on the bottom, right.
Now, it brings up the airport plan, or the first approach in the list ... but not the approach selected in the navigator. If click away and back, it seems to have forgot the previous setting and goes back to some other chart. I have manually select the correct approach plate now....
How does one set up the display with the side-by-side MP and RPM arcs?
I‘ve dug in the manual and tried everything in the configuration menus and can only display round indications, one above the other, on my single GDU-470.
What am I missing?
Menu-Menu-Setup-Display-Set EIS to combined (or separate).
It’s not necessarily that simple. I worked with G3Experts and was never able to get the configuration correct to do this. Some options aren’t there if you have certain configuration options set. For example, in config mode, “fuel gauges are set to separate for fuel display. If you change that to normal it will give you the option to change the EIS Layout Size. In user mode, in the second picture, I have changed the PDF EIS/Engine Page Layout to SEPERATE, and changed the PDF EIS Layout Size to NARROW”. Concatenated from several emails…
He tried to send me a working config file, but found out he couldn’t attach it to an email, same with photos (all I got were unreadable .dat files). I finally gave up. Wish you better luck.
I think you must mean GDU 460, since you would never see vertically-ordered engine gauges on the portrait display of a GDU 470.
What you are asking about is a feature of GDU 4xx software version 9.31:
Improved density of EIS display on GDU 46x when EIS / engine page layout preference is set to 'separate'
What this means is that the extra-compact layout of the EIS area - where pairs of round gauges are shown side-by-side with reduced size - is possible when "EIS / Engine Page Layout" is set to "Separate", but not guaranteed. In practice, the software will typically do this only when it is necessary to accommodate all the engine gauges you have configured to be displayed.
If you have "EIS / Engine Page Layout" set to "Separate" and the RPM and manifold pressure gauges on your GDU 460 are being displayed full-size on separate rows, it's because there is no need for the software to use the extra-compact layout to accommodate all the gauges you have asked it to display.
I'm also interested in this - I definitely have more gauges than fit on the left bar, yet MAP/RPM display on top of each other.
@g3xpert any chance you can let us know what the actual logic to display gauges side by side is? There's indeed no mention in the manual. TIA
This solved the problem. I had to have those other config items set, but in order to get the RPM/MAP gauges to cluster, you have to add the additional indicators until there are enough to be necessary to condense the display.
Thanks a lot!
Today I did some more fine tuning of my tick mark showing the correct take-off elevator trim and, in the gauge preview mode can see exactly where my elevator trim is (+15) but when I go out of config mode reverts back to showing tick mark changes (Which is far better than having to use my laptop to change tick marks in VPX) but not the location of my trim. !4's are pretty pitch sensitive and doesn't take much of a trim incorrectly set to require a decent amount of stick pressure and trim adjustment at departure. It would just be nice to know where my elevator trim was set before departure. Guessing at the tick marks are +/-5 to 10%. If anyone know how to correct this great or maybe in the next upgrade, we can see exactly where our elevator trims are set. Thanks
Not sure I follow what you are saying... in config mode you set up the trim gauge the way you want it, and then before takeoff you adjust the trim until the pointer is in the correct position relative to the configured gauge markings.
In config I can see the exact location of the elevator trim (+15) in the picture attached above but when I take it out of config the +15 is gone and can only eyeball the indicator to the tick mark. (I do have an alarm set when I don't set it +/- 5 to desired setting) but would be nice to see exactly where the trim is set. (Like in the config mode) Isn't the gauge preview mode supposed to look like what you are actually going to see? This is using a VPX.
Yes, that's very normal. The reason a number is displayed in config mode is so you know what to type in when you are configuring your gauge markings; it isn't needed otherwise.
Try to use white lines instead of tick marks.
Hi G3Xperts
I just installed 9.41 (from 9.22) on a panel with a Trutrak Gemini. In doing a ground check the autopilot now disconnects itself after about 5-10 seconds.
Also noticed that AP CANNOT be turned off from the G3X any longer. It must be disconnected from the button on the stick.
Are these bugs or expected. And how do I set these back to the way they were prior to this upgrade because I don't see anything obvious in config mode.
Hi G3Xperts
Oh yah, and blue button no longer functional. "straight and level" doesn't engage the autopilot (at least not on the ground).
A full power reset of the panel seems to have improve things. Suffice it to say the reboot as part of an update is not sufficient to restore proper function after a software update. Power off and restart.
cheers.
Does the TERRAIN INHIBIT discrete in option mute the terrain warnings only or does it remove the terrain colors from the screen as well?
I'm thinking about a useful labeling of a dedicated switch with 'TERRAIN MUTE' if it kills the terrain audio warnings and pop ups only..
EDIT: I have checked the behaviour in demo mode today (Terrain Warnings INHIBIT); the voice warnings were muted and colored scheme (yellow and red) remained on the TERRAIN page.
