SeanB
Hi,
I’ve now conducted a few flights in Phase I and have a few bugs to resolve. One, is the aileron trim indication on the PFD being backward. I am also using a VPX Pro. The physical movement of the aileron trim is correct when using the hat switch and correct when using Autopilot. But, the aileron trim indicator on the PFD is slightly off center and backward. Inverting this on the VPX literally flips movement (polarity), so no good. Is there a configuration in G3X to resolve this issue? BTW, behavior and indicators for pitch trim and flaps are correct.
Thanks!
Thanks!
