G3X Losing traffic
A friend of mine was flying next to me. He was only running a transponder. When the traffic would disappear his plane would still show up but no tail number or anything. Just the diamond.
I would share that piece of data with Garmin, as it is good troubleshooting data. The loss of the Number implies a short coming with the transmission. The other sysytem kept presenting with the limited data, but garmin did not. This implies some poor error handling code that used an all or nothing approach when deciding to call the input failed and error out the routine.
Larry
Larry
I just sent over another email with the information from yesterdays flight.
I sure hope this gets fixed. I could see the only way around this is to buy an extremely expensive transponder. Not something I would want to do nor think I should have to do.
I just completed two short flights with ground based traffic dropouts on each flight. The Garmin Pilot App. never lost the ground based traffic! TIS-B client was 66.7% and 51% at 5000 ft.
I don't think it's the Transponder; I recently did a 5 hour flight from Little Rock to Jacksonville FL. and lost my ground link nearly half of the trip. Air to Air was up 100% but TIS B was only 42%. G3X Touch paired with a GTX45R. Latest software on both. It sure looks like it is a G3x issue.
So just to be clear, even with your air to air at 100% all your traffic disappears off the g3x?
Well, I don't know what I'm not painting. I do know I'm getting drop outs of my ground TIS-B data link for extended periods of time. Air to air is reliable for other aircraft broadcasting ADS-B data. I have not compared a tablet display, running concurrently, like others in this thread.
Good Morning,
We will roll out GDU 4XX v9.32 in the coming days. This update will include an update that will address the intermittent "No TIS-B Service" and associated loss of traffic information. Thank you for the feedback provided that assisted us in diagnosing the problem here.
Justin
Good Morning,
Justin
Justin, thank you for the information! I hope this solves the issue. I’ll install right away once it hits the site.
Good Morning,
Justin
Thanks for closing out this ticket. Looking forward to renewed confidence in the G3x traffic display.
Good Morning,
Justin
when will we see this for the 3xx units? I have been providing inpput on this problem for 3 years and a 4xx update does me no good. I also would like to have reliable traffic on my G3X.
Larry
Received an email from Garmin today saying the engineers have a fix that will come out in an update. To watch the Garmin update page for the release “mid-year”.
Larry
Larry, I would definitely give Garmin a call and inform them to include the 300 series as well. The email I got said the update won’t release until “mid-year” so based off that they should have plenty of time to include all models.
I submitted a ticket to the FAA last week with a writeup of the issue. Just received the following response from them.
Thank you for your report. We have confirmed that the indications of low levels of TISB service that you are seeing are due to a software issue in one of the processes in the ground system. The resolution of this issue is underway, but we do not yet have a firm date for deployment of the fix.
This issue is inhibiting the generation of TISB service status messages, which avionics use to identify times TISB service may not be available (when TISB service status messages are not received, avionics will infer that TISB service may not be available).
It is important to note that this issue is not affecting your actual TISB service. You will continue to receive TISB target uplink messages when a TISB target is in your vicinity, even if you are not receiving TISB service status messages.
We will advise you when the software fix is ready to be deployed.
A little bit of history repeating 🫤
I just checked the G3x update page and 9.32 is out. Hopefully I can get it loaded into my plane and give it a go between the rain.
Well I hope the software fix does it, but I would like to offer a couple additional data points just in case there are multiple problems going on. It appears that the G3xperts read this thread, so maybe this will be helpful.
I have a GDL-39 and GTX-23-ES transponder connected to dual GDU-460s. One GDU is RS232 connected to the GDL-39 and the second is Bluetooth connected.
When on the ground, even in my hanger with the door open, I see traffic 24 miles out via ADS-B, and there is never an interruption on the G3X screen or an iPad connected to the GDL-39. However, when in flight I get traffic dropouts on both GDU-460’s anytime I see the TIS-A notification on the traffic screen. It feels like getting TIS-A data interrupts the traffic data from ADSB. During this time I see no traffic on the GDU460’s but a connected iPad will still show traffic.
TIS-A data comes in via the GTX-23-ES transponder, while ADSB and TIS-B comes in over the GDL-39. So an iPad connected to the GDL-39 does not get TIS-A, which would explain why it is not affected during the dropout on the G3X.
The G3X system will prefer TIS-A over ADSB data. The solution is to go into the remote xponder configuration and disable TIS-A.
This is true only when TIS-B data is not available, which makes sense when you think about how the various traffic services operate.
Thanks for clarifying Matt! My memory is starting to get foggy on the details since I don't have a bird anymore. I went back into my notes and found this:
"G3X Traffic Priority:
1. GTS 800 Active Traffic System
2. GDL39/39R ADS-B traffic system receiving both air-to-air and TIS-B
3. GTX23ES/GTX330ES TIS-A traffic system receiving TIS-A
4. GDL39/39R ADS-B traffic system receiving only air-to-air"
While there are new products since then, I assume the general concept of priority remains the same?
I also have GDL39R with GTX23ES transponder, and I also experienced “many” incidents of traffic dropout. I changed my config to turn off TIS-A on the transponder, and it has eliminated traffic dropout - including a 4 hour trip this weekend. Anecdotal, but a very positive improvement.
Thank you for the great responses. I was thinking that turning off TIS-A may solve this but had not tried that yet. I will give it a try and report back. It does seem like TIS-A is taking priority over ADSB / TIS-B rather than combining them. But very little traffic is being shown with TIS-A when this happens.
I flew from the Sacramento area to southern CA this past weekend after the new update. I didn’t have any drop outs even going through some remote areas.
Just Incase though, where do you turn off the tis-a at on the 23es remote transponder?
It’s in the config mode on the G3X, go to the remote xponder settings.
Wanted to let everyone know that Garmin pulled the 9.32 shortly after I grabbed it off their site. It’s throwing an LRU message. I called and they said they put 9.31 back on the site and the new update should be out shortly that doesn’t have the bug that sets the LRU message.
I flew with it several hrs and didn’t have any issues.
yes, I'm a bit late to the party ;)
Still running 9.31 on the 3GX, I too noticed loosing traffic on the GDU470 whilst it was still displayed on the GNX375...
Hey, please add scratch pad, it should be quick......
I finally got out flying today and I am having the same issue. Traffic will be shown and then disappear. Sometimes a minute or two later, it comes back. It is very distracting. The interesting thing is it was showing up on my ipad with Foreflight connected to the Garmin G3x system and GPS antenna.
Flew for a short flight today. I’m still dropping traffic with the updated software 9.32 and my phone or iPad still shows the traffic.
Doesn’t seem to be doing it as often and seems to drop out just after takeoff even though I show traffic while I’m on the ground.
I’m not sure if Garmin has this completely fixed. I’ll wait to send them a message after the update is placed back on their site Incase they have changed anything.
The problem that Garmin is working is different than many of us are experiencing. I think whats happening is that the G3X can’t display traffic from more than one device at a time, and it prioritizes a device based on a fixed set of rules. ADSB (GDL-xx) wins when both air to air and TIS-B are being received. But with ADSB air to air only, then TIS-A (from the transponder) takes priority when it’s present. The problem is that TIS-A only includes aircraft with mode A or mode C transponders, which are now very few. So, it appears like all traffic is lost. The option is to disable TIS-A in the transponder if you are running a GDL-xx and have a TIS-A capable transponder like the GTX-23-ES.
This is part of a post by G3xpert back in 2016:
A couple of things to check.
We know you have a GDL39, a GTX 330ES transponder, and a GPS 20A installed with your G3X system, so you actually have two traffic receivers. You receive TIS-A traffic from your GTX330ES and ADS-B traffic/weather from your GDL39.
As you probably know from the pilot guide and our past postings, if both of your traffic receivers are enabled, the G3X system will prioritize them and use one or the other depending on which might be providing the best traffic information.
1. GDL39/39R ADS-B traffic system receiving both air-to-air and TIS-B
2. GTX23ES/GTX330ES TIS-A traffic system receiving TIS-A
3. GDL39/39R ADS-B traffic system receiving only air-to-air
You will note that full ADS-B traffic with TIS-B ground uplinks takes priority over GTX330ES TIS-A traffic, but for those probably rare times when you are receiving TIS-A traffic and not TIS-B traffic, the TIS-A traffic takes priority and this traffic does not include Flight ID.
Many of us disable TIS-A traffic on the Mode S transponder (I did this in 2012) because ADS-B traffic is almost always better and we don't like ever seeing the system switch to TIS-A traffic. You might do the same (via the transponder configuration on the GTX330ES) to keep things simple.
Secondly, and probably more importantly, you might want to check your Traffic settings for the Map page. From the MFD map page select Menu, Set Up Map, and then select the Traffic Map Setup page.
From this page you may separately control the map range dependent declutter settings for the traffic symbol and traffic label (Flight ID). The default setting is Auto which will remove the traffic symbol and label at MFD map range settings of 12 nm and above. I personally find this Auto decluttering too aggressive, and change mine from Auto to a fixed 30 nm on both to keep the traffic symbol and label visible on the map even when zooming out quite a bit.
Another tip. The two traffic symbol icons on the upper right of the map which show if you are receiving TIS-B ground uplink services and air-to-air traffic also declutter (are removed) when the traffic indications are removed from the map, so this is a quick and easy way to tell if your map is zoomed out so far that traffic has been removed to decrease map clutter.
Steve
Steve
I went in and took the ‘tis-a traffic out of the transponder and with 9.32 software I’m back to ADSB in working 100% of the time on my g3x screen. Flew up to the lower mountains today and never lost traffic one time.
So I would recommend going to the 9.32 and the. Getting rid of tis-a once the 9.32 is back up on Garmins site.
