I'm going to be using a fuse block in my RV4 and am wondering what the conventional wisdom is regarding location. Also would like to know about where folks mounted the ground bus.
You can put your fuse block anywhere it's convenient. Since you won't be trying to change fuses in flight, just put it wherever makes most sense for your installation.
