danielhv
I just finished patching a leaking tank... so in a week or so I'll pressure test, and then hopefully install it onto the wing spar for good... (Is there any other reason to remove it?, should I wait before I go torque sealing everything?) My question is what do I do about fuel sender wiring? I'll obviously need to hook it up and have the wire sitting loose somewhere... do you guys just run it along the forward side of the spar between the tank? Or take it down into the wing conduit somewhere? And what kind of wire do I use?
