Fuel tank and Fuel line questions
ravenstar
Patron
There are days building an RV-12iS when everything seems to be going smoothly and the plans all seem to make sense, and then there are days like today when I wonder if I can even understand simple instructions. I assembled my fuel tank out of order last summer in order to take advantage of the warm weather to work with the Proseal. Then SL-0070 came out and I waited until warm spring weather to work with the sealant and finish installing the inspection port. In between I made some of the fuel line components and finished all the fuselage steps that would allow me to test install the fuel tank as shown on the final page of section 26. It's there that I've begun to doubt my work.
First problem: The fuel tank seems to fit very tightly into the baggage compartment. It looks like the AK-42H rivets are as flush as I thought. The heads are slightly domed and bind on the F-01204J bulkhead flange caps. I'm not sure that's the real problem, though because once I managed to get the tank in place, I still had trouble getting the NAS1149F0332P washers in between the tank and the bulkhead flanges because the fit was so tight. Is this typical of how tight the tank fits? I think it would be a nightmare to remove the tank with the canopy in place with such a tight fit. It's certainly not possible to put it in and remove it without marking up the flange caps as far as I can tell. I fear I may not have countersunk the holes in the T-01225 flanges as much as I should have, which may mean rebuild the fuel tank.
Second problem: This is relatively minor, but there is no mention in the plans of dimpling the screw holes in the F-01229-1 and F-01229A panels but the underlying screw holes are dimpled. I assume this is an oversight? It's more confusing because where these panels are installed in section 38, AN526C832R6 screws are specified, but none were supplied with my kit. It seems like it would make more sense to dimple the holes and use AN507C832R8 screws (of which I have ample numbers) for this panel. I was willing to just go ahead with this plan, but have lost my nerve after seeing how difficult it is to properly place the fuel tank.
I'll mention my third concern, involving the F-12127K fuel line from the shutoff valve to the tank. I carefully measured this line according to the instructions and I think I was very successful in bending it to match the drawings, but it looks like it's very short. I couldn't hook it up to the fuel tank because I had left the pressure testing fittings on the fuel tank when I test installed it thinking the job was going to be easy. But it seems like it is almost a half inch short. I've confirmed that the drawings are to the proper scale, so I didn't mis-measure the bends. I'll recheck and tweak the bends or remake the part when I next install the fuel tank, but it left me wondering in general what the tolerances are on the rigid fuel lines? How much are you able to manipulate the lines for the final installation?
Would someone be willing to share their experiences with these parts?
Thanks!
I can confirm that the fit is VERY tight. I have not done final assembly yet, so I'm not sure what I'll do about that. But if the only issue is not getting that washer in there, I'll skip it.
I managed to get the washers in with a washer wrench I bought to place the washers for the horizontal stabilizer. One side just barely fit, but on the other side it took two of us pulling and pushing the fuel tank and side apart even to start the tool which is thinner than the washer. The tool definitely was worth the money in saved frustration.
Yeah, I have a set of those washer holders. Would not be able to install the rudder and other parts without them.
I'm just not sure what good that washer is doing. If the fit was loose, then it would make sense to keep the tank from moving.
I think I've solved my second problem. After scratching my head for another hour looking at the floor, the plans and my build notes, I don't think the holes really are dimpled. It's an illusion from the paint I've applied. It doesn't explain why there were no AN526C832R6 screws in my kit, but at least I don't have to do any more work than order a few dozen screws. They're used for many of the access panels over the fuselage.
EDIT: And the mystery of the screws is that they're supplied in large quantity with the finish kit.
To make my public humiliation complete, I test fit this line today and it was indeed almost an inch short. In frustration, I straightened out the tubing and remeasured it. I'm sure you can guess how it turned out: The piece was 24 1/4" instead of 25 1/4" long.
Some days....
Some days....
I think the kit came with 28 feet of tubing. I used every bit of that and most of an additional 28 feet to finally get it right.
I bought 6' of extra tubing and some fittings to experiment with before doing the actual assembly, but I started with the smallest parts and those went well enough I think I got overconfident. I'm happy to say that the remade pieces cut to the right length fit perfectly. I still have the two longest segments to fabricate, so I'm not out of the woods yet. As to the precision of the bends I was concerned about, at least on the longer sections, if they look like they match the shapes printed in the plans, they seem to fit without any difficulty. I won't know about the smaller pieces until my powerplant kit arrives and I assemble the fuel pumps, but I'm much more optimistic than at the start of the week. Thanks for the encouragement.
My Tank is also a tight fit. It’s great that Van’s offered the SL70 mod for inspection as I’m not looking forward to removing the tank from the finished airplane.
I'm sure a lot of us have had to remake lines because of measurement issues. I did. A line I took from another builder is that “they give you enough tubing to make all the fuel lines but not enough to learn how to make all the lines“.
Just for clarification…
The RV – 12iS maintenance manual has never prescribed removing the fuel tank during the condition inspection.
The issue was that you had to 100% drain the tank to remove the pick up screen and inspect it.
With the SL 70 modification, draining the tank is no longer necessary as long as you have access to an inspection camera that can be inserted through the hole in the flange on the top of the tank, once the plug is removed.
Scott, the issue being described is for an aircraft with the tank already installed. Unless you have some trick, the tank has to be removed from the aircraft to access all of the screws on the fuel-sender mounting plate for removal. Or doesn’t it?
Maybe I misunderstood the comment…. It sounded to me like he wasn’t wanting to remove the tank and that “with the SL 70 mod, now he won’t have to “
If inspection of the screen using a camera through the inspection port reveals some fine debris on the strainer, will it actually be possible to clean the screen without removing the tank?
F-12127K (fuel tank to fuel shutoff valve) is a little bit of a pain to produce correctly because of the 38 degree bend very close to the end of the tube. I had a very very slow leak in that fitting for a couple years until I finally broke down today and removed it and re-made it. It might be my cheap tools, but I wasn't able to get the bend as close to the end of the tube as prescribed.. First attempt.. I connected the tank's fitting.. then tried to manhandle the 90-degree bend to the shutoff valve.. but it was a hair too short (because that 38 degree bend was farther down the tube than planned).. Second attempt, I made the tube 1/4" longer than prescribed.. and I was able to get it attached OK. Now I remember why I left that leaky tube in for so long!
I also remember the rivets slightly interfering as I slid the tank into its final position. Wasn't a real problem though..but they did rub as it was sliding in. Even though I countersunk them correctly.. I think when you spin them in fuel tank sealant and pull the mandrels, the sealant makes them sit a little more proud than expected..
Lastly, since I emptied my tank today to replace the line.. I was able to get a borescope into the tank.. and after 5-10 minutes and 10 attempts at inserting it, I got it successfully navigated to the center area of the tank where I could see the finger screen. Recommend adding the inspection port.. but not impossible to view it without the port.. just takes some time and luck.
Good rule of thumb IF you havent worked with tubing alot----buy and extra roll. Its inexpensive. Spend some time making various bends and flares, until they are good. Yes it takes time, and even those of us that bend quite a bit of tubing (mine or prototypes by hand, NOT the CNC versions that are perfect fits) we still make some practice tubes. You can also leave 1 end long and cut to fit AFTER a test fit. Yes---carefull measuring of the straight length and compensation for the bends equals the correct length tube.
I have a question about tank removal during the condition inspection. Page 3-4 in the maintenance manual list the tank as one of the items to remove. I do have the SL 70 modification installed. Our mechanic believes the tank should be removed. Not sure how to remove it without scratching the rear window.
I cannot imagine why one would remove the tank for a condition inspection. It can be done with the rear window in place, but it is a PITA even with a nicely-fitting tank. I'll go out on a limb here and say that Item #20 on p. 3-4 of the Maintenance Manual, which calls for tank removal, is an error. Inspect the screen for crud, inspect the fuel line fittings underneath for leaks, inspect elsewhere for leaks, but do not remove unless problems are found. If your mechanic is insistent, ask him or her to call or write Van's Tech Support first and ask.
I became an expert in the removal of fuel tanks as I ended up with two leaking tanks that needed to be addressed. It is possible to remove them w/o scratching the rear window, but it is not possible to remove them without a large numbers of expletives. Because I ended up ruining an otherwise perfectly good tank by cross threading a Fuel Strainer, I was very happy when SL - 00070 was released.
SL-00070 implicitly suggests that its purpose is to permit an alternate method of compliance with "inspection and cleaning of the Fuel Strainer". Unfortunately, the SL does not explicitly state this in legal terms. Hopefully, if your mechanic reads the SL she/he will conclude that the inspection port is adequate to meet the spirit of the Maintenance Manual.
Prior to installing the rear window, turtle deck skins and fuel filler hose I was able to get a good view of the fuel strainer by manoeuvring a boroscope camera past the baffles then down towards the bottom of the tank. It will be tricker now that rear window etc. are installed; but I am hoping it will still be possible if I remove the fuel filler hose.
