Bob's conundrum has got me nervous about the fact that I have not pressure tested my -IS fuel system. I think it would be a good idea to do that before my Avionics kit shows up and I start filling this thing full of wires and modules. That being said, the engine is mounted and hooked up as much as I can at this time and that includes the fuel lines.
The question:
Is there any reason I should not pressurize the entire fuel system with the exception of the fuel tank? Would doing so, with the engine connected, put the fuel rail regulator or injectors in any risk of damage?
I plan to plug the lines where they connect to the fuel tank, use the fuel pressure transducer port for a pressure gauge and the fuel drain manifold for the Schrader valve.
The question:
