RudiGreyling
Hi RVators,
My RV7 is about 1 year old and lately if I switch the standard Vans Supplied Fuel Injected electric pump on (during Take-off & Landing), I get a fuel smell in the cockpit.
I have confirmed with at least one other local builder he gets the same on 2 of his RV7As he build to exactly to plans, on the same standard setup.
I have taken the entire center floor pump cover section appart many times trying to trace this but to no avail.
My current modus oprandi is not to use the standby pump, to eleminate the fuel smell, but that is not ideal either.
Here are my questions:
1) Have you RV7/7A Fuel Injected drivers experienced the same?
2) How have you solved it?
3) What is the best method to trace a fuel smell? My approach of looking for gas seepage has failed.
Thank you in advance,
Kind Regards
Rudi
Kind Regards
Rudi
