f14av8r
Please see the attached photo. This is a Superior Sump on an IO-360. The Fuel Servo linkage bracket is blocking the sump port that I'd like to use to return oil from the canister on my inverted system. I'm currently using one of the bottom ports but that's not optimal.
Any ideas on how to modify this bracket to allow access to the port and installation of a 90 degree fitting which will face horizontally towards the center of the engine - (fitting would be pointing to the left in the photo when installed).
Thanks!
Randy
Thanks!
Randy
