Educate me - on my fuel pump lines from Aircraft Specialty, some lines have nuts with the sleeves, and some have nuts that have no sleeve. Why the difference? For example, this line going to the pump - one end has a nut/sleeve and the other end just the nut. The line going forward from the pump to the firewall also has no sleeve. Do not all flared fittings require that sleeve for the nut to compress against the flare?
