fuel pressure
dick seiders
cranked today and during latter part of warmup (it was cold 28 degrees) B>Betty said LOW FUEL PSI. The dynon psi indicated FULL max psi. Did'nt know what was happening for sure altho I suspected the fuel pressure sensor so I shut down, and plan to try a new sensor tomorrow. While looking at the engine after removing top cowl discovered a small leak of coolant coming from hose on no. 3 cyl which of course is the most difficult to get at. Good news is it was found
Any comments on either topic is well appreciated.
dick seiders 120093
