constantin_w
Member
Hi guys,
I am having some trouble with our RV-12, 912 ULS with Dynon D180. We keep experiencing wildly jumping fuel pressure gauges with frequent high fuel pressure warnings. The jumping gauge can also be seen on the ground but the warning comes mostly up on decent which points on some issues on the flow back to the tank.
We have already changed the fuel pump, the fuel pressure sensor and some fuel lines. We did check the valves as well. In general, the problem seems to disappear after some maintenance and comes back after a while. Today we had one warning on the ground which went away quickly. Not a single warning in the pattern (did 4 circles), but in the next flight (ca 4500ft MSL, WOT, 4900rpm), the warning kept coming up during decent again.
Did anyone of you experience a similar problem? Any idea where to look and how to solve the problem?
Thanks for your help in advance.
BR
Conny
BR
Conny
