oren_rokach
My fuel pressure , with fuel pump off, is fixed at 25 PSI. w/fuel pump at 27.5psi.
Very stable. my hazard is set at 24. and never reached this hazard.
Yesterday, while performing some manuvers, When staightening after climb (maybe just a bit less than positive 1G). Fuel pressure dropped to 20-21.
Is it normal? if mechanical pump is still operational (obviously), does it mean that fuel is not pressent at suction point at the wing?
Engine was stable, If i wasn't too strict about the threshold, I wouldn't even know that the drop exists.
Your thoughts? is it common?
