Has anyone fitted/installed the fuel lines before installing the belly skin?
Some templets could be made to accurately locate the fuel pump, fuel valve, and flow scan for fitment and the skin braces, F1204Z, in the gear channel (F1204 assembly) would insure the correct lengths. The forward belly skin, F1272, and lower firewall, F1201C, could be clecoed in place as well. Before riveting the belly skin on the system blocks, F1276C, system block studs, MS35206-248,and snap bushings would all have to be installed
Just askin......
Thanks, Dave
Just askin......
Thanks, Dave
