The KAI includes detailed instructions (and a kit) for pressure testing the fuel tank. But, when it comes to pressure testing the fuel lines, not so much.
I don't yet have the fuel pump that ships with the engine. Therefore, I believe I need to bridge the IN & Out lines of the bulkhead fittings, the fuel pump and the tank.
One of those bridges will include a pressure gauge and Schrader valve.
Then I pressurize the system and test each fitting with soapy water.
Someday, I'll need to re-test with the fuel pump and engine connected.
I'm wondering:
1) Is all that correct?
2) Should I use a Home Depot quality pressure gauge and related fittings?
3) What pressure should I use for a 12sI fuel system?
Thanks in advance.
I'm wondering:
Thanks in advance.
