Thought I would post a heads-up for those who have not yet installed their fuel senders (float type). A dumb mistake on my part, but pretty easy one to make. I am building an RV-8QB.
I started by modifying my left tank for the flop tube per the plans, which entailed moving the fuel level sender to the back baffle of the second bay. I grabbed one of the fuel senders Vans sent me, bent the wire per the plans they send with them, then drilled a large hole in the rear baffle for the sender and five smaller holes corresponding to the location of the screw holes in the sender. The location of the holes is important, otherwise the sender could be mounted at an angle with respect to the tank. It all turned out great, so I installed the flop tube and other parts and sealed that sucker up. (Anyone see the error yet?)
I then set it aside and got out the right side tank. No modifications are required on this one (other than SB compliance), just mount the access plate, then mount the fuel sender. I put the sender together per the plans and mixed up some ProSeal. (Anyone see the error yet?). I ProSealed/screwed on the access plate, then slathered ProSeal over the sender and stuck it through the hole. Uh oh, I see a problem now - the screw holes in the sender don't line up with the screw holes in the access plate. I didn't expect any problems here since the screw holes in the access plate were already drilled with the nutplates mounted by Vans.
A few minutes of head scratching and I come to the conclusion that Vans accidentally installed a left hand cover plate on the right hand tank.
Darn amateurs! Still, something doesn't seem right... (Anyone see the error yet?) Oops.
A dim light comes on over my head. Sure enough, a closer look at the plans reveals that there are left hand and right hand fuel senders complete with different parts numbers! (F-385C vs F-385B).
There isn't anything explicit in the plans, other than a reference to F-385B/C. And of course, the parts aren't marked with F-385B or C, since they aren't made by Vans. Luckily I can remedy the problem just by ordering another sender. Anyone need a float type sender for the left tank?
This would not have been a problem if I hadn't made the inverted mods. Or if I had started with the right tank. Or if I had both tanks side-by-side while I was working. Or even if I had come out on top in the 50/50 odds that I would get the two backwards. Or, of course, if I had read the plans and compared part numbers.
Hope this helps someone out there...
