A few years ago, I had a similar thing occur (see attached pics). It would look exactly like your pic with the "goo" on the side just like what you have. The fuel came out of a communal 100LL fuel tank that somehow got contaminated. We finally figured out that it was some sort of microbe that grew in the fuel. There may have been some water or rust contamination that also contributed. This is known to happen in jet fuel but seldom in avgas but it can happen. Bottom line is that this stuff was able to pass through a fuel filter (that was also supposed to stop water) and my fine screen fuel filter and make its way into my carburetor. It would corrode metal (especially any steel) and finally caused my carb accelerator pump to stiffen and almost seize. It would pass through and then grow or somehow accumulate to a jelly like consistency. After we identified the source of the bad fuel we had a really hard time eliminating it from our aircraft tank. After doing a lot of sumping and draining and not seeing any more, we would still occasionally see the same thing. It was very persistent.
Finally my friend determined that the best way to fully eliminate it was to completely drain the tank and system again and then set up a small blower to continually blow air into and out of the tank to COMPLETELY dry out every nook and cranny. It seems like the drying finally killed the microbe where fine filtering didn't do it. After that (plus never using that supply tank again) I have not had any problems. If it were me, I would do what Roadjunkie1 said and drain everything and put that gas in your lawn mower.
Good luck
Keith
I have to add to Keith's response:
Keith (Tailwind/RVGuy) and I have traveled (I have an RV4) across country together many times. At the time of this fiasco we both obtained our fuel from the fuel farm on our airfield. We encountered this contamination while in route to Montana. I tried isopropyl alcohol in my tanks, which did not make any improvement. We probably filled our tanks 3 - 4 times on the trip and the contamination persisted. After much investigation and discussions with the people at Biobor, who were a great help, fuel supplier people, who were no help, fuel tank service people, who were also of no help, we have arrived at a solution.
1. This contamination is a bacteria that likes rust and water. Its not common but does happen in the marine industry more so than the aviation industry
2. Rust and this bacteria
will pass through any filter or filter screen. Over time it becomes coagulated - the orange jell.
3. It is not easy to remove.
4. In aircraft systems, the tanks and fuel system need to emptied and completely dried.
5. If you are using a in-line filter, Please check it! If you have a carb, pull the float bowel and check it. This stuff is corrosive
6. Change the source of fuel supply - I changed where I buy fuel.
7. Fill your tanks and add Biobor JF biocide (shock treatment amount)
8. Use a maintenance amount of Biobor JF for the next tank fill.
9. Even after all of this monkey motion, I still have had to treat my fuel tanks with Biobor on two more occasions.
10. This our experience - your results may vary.
If your fuel storage tank is contaminated - follow the same process, adding a thorough cleaning of the tank and make sure it is dry. Replace all filters. Shock treat the tank when you refill it.
I have a gallon glass jar that I test the fuel from the storage tank on a regular basis. The orange jell particles will appear on the sides of the glass just like you see on your sampler.
Again - this is our experience and solution. I would be
very interested in your solution.
