Fuel Installation Schematics for POH
supik
You may find this useful for your POH if you run the same setup.
EDIT: Admin pls move this thread / post to the RV10. POH Section.
Hello Igor,
I really like your diagram of the fuel system. Is it possible to modify it to show a system with wing root filters vs gascolators, adding a second electric fuel pump, removing the mechanical pump, fuel flow cube and adding a return line to each fuel tank, etc.?
There are a number of us 10 builders who are going with either SDS or Fly EFI systems that could use a diagram for our POH information.
Best regards,
Keith
Hello Igor,
Best regards,
Keith
Hello Keith,
I'm too busy with other things right now, but maybe I'll find the time in future to modify the diagram..
my best,
