Hi All,
Fuel Flow Transducer (Red Cube, FT-60) – possible to repair?
My FT-60 failed after 177 hours – was installed between fuel servo and spider. Not isolated from heat – so probably this is the reason.
Mechanically everything looks good. Probably electronic parts were overheated.
Question – is this unit reparable? Can somebody exchange the electronical part of this unit?
It cost now around USD 250 so maybe would be worth to repair it. I suppose the most expensive is the mechanical part of this unit.
Witold
Witold
