Captain Avgas
rocketbob said:I honestly don't understand the mentality that exists in the garage-built crowd anymore where something you read must be followed as gospel, and alternative ways of making things are frowned upon just because someone says there's no data to support what one is doing. EAA- EveryAirplaneAlike.
Bob, this is a delicate situation because I certainly don't want to discourage builders from putting forward ideas and you are to be commended for contributing.
However there is a lot to be said for encouraging the adoption of techniques that have been proven successful in mainstream general aviation over time. This is particularly true of FWF installations where failures can be particularly disasterous.
One of the major advantages of the Experimental category comes from the ability to "experiment".....but that is also its weakness. The use of internet forums to source construction advice can be invaluable...but it can also be dangerous. It's a double edged sword because there is so much advice being proferred on adhoc and untested installations.
Look at the recent Mark Chamberlain thread. http://www.vansairforce.com/community/showthread.php?t=19711
This gentleman is probably lucky to be uninjured because he has had 2 engine failures and forced landings in recent months. The first, because he installed an electronic ignition system with virtually no track record. The second, and most recent, because he experimented with using a rubber mat to seal his air filter...and it came loose and was sucked into the throttle body.
We owe it to ourselves, to our passengers, and to the Experimental movement at large, to do the proper research that will allow us to use time tested and proven construction principles. As they say....with freedom comes responsibility. Because without the latter, the former can quickly evaporate.
