Sounds like a simple thing, but I can't find instructions for hooking up the fuel level floats in my wings? Can anyone point me to the proper section in the directions or send a picture?
When you find the prints, be real careful not to forget the 1" 90 degree bend at the end of the float rod. This goes through the hole in the float arm holder to prevent the rod from rotating in the float arm attach clip.
Many - many builders miss this on the print as it is not obvious.
