Tandem46
On August 7, 2005, approximately 0900 mountain daylight time, a Sheel Vans RV-8, N5754S, piloted by a private pilot, was substantially damaged when it impacted terrain during a forced landing near the Fort Collins/Loveland Airport, (FNL), Fort Collins, Colorado. Visual meteorological conditions prevailed at the time of the accident. The flight was being conducted under the provisions of Title 14 CFR Part 91. The pilot was seriously injured and the passenger sustained fatal injuries. The flight was originating at the time of the accident.
According to an FAA inspector, the passenger's wife dropped him off at the airport shortly before 0900 for a personal flight with the pilot. Witnesses at the airport reported seeing the airplane in a steep left bank "like it was trying to land on runway 15. Suddenly, the plane made a steep, abrupt (approximately 45 degree) nose down descent." The witnesses said that the airplane pitched up when it was approximately 50 feet above the ground and impacted the ground in a "wings level, slightly nose low attitude."
Postaccident examination by an FAA inspector revealed that the left fuel tank was empty and the fuel selector valve was on the left tank. The right fuel tank had approximately "one inch" of fuel in it. One blade of the propeller was bent under the engine cowling, and the other was slightly damaged.
