Whirl Wind Propellers
Member
WhirlWind Propellers is looking for a RV-10 owner in SoCal area to evaluate our new 300-77 series Constant Speed propeller designed specifically for the RV-10. Two other production models have flown the past yr. Flight evaluation has proven smoother operation, increased take off acceleration, better climb, with no loss in cruise speeds. Propeller construction is Aluminum hub, carbon composite blades, Nickel leading edge for abrasion protection. Significant weight savings with an all up weight including spinner of 40 lbs. Gloss carbon finish with tips and polished Ni Leading edge is standard.
Looking for someone who flies at least 100 hrs. /yr.
Specs:
300series-76 diameter
Wt 40lbs
Pressure to increase pressure to increase pitch/ standard governor will work.
Contact us at 619-562-3725 or [email protected]
Specs:
Wt 40lbs
