I needed to pull a carb and to do so the choke cable needed to come out as many others I am sure have experienced. I had some heat shrink on the end but it needed to off to remove the cable.
Well to go back together the cable, starting frayed, just progressively got worse at I tried to re-insert the cable into the barrel where the cable is held in the choke arm. I got it through but is not pretty and likely could not go through this again. I am trying not to have to buy a new cable system to the tune of $96 + shipping.
Are there any techniques to re-twist a cable end? Or a device that can be attached to a shortened cable and be inserted into the choke mechanism? What about enlarging the hole in the barrel a little bit?
