David Paule
As I first see the new forum design, it's hard to read - the font is small and the contrast against the background is too low. Is htere any way for me to change those?
Thanks!
Dave
Thanks!
Dave
Try “Dark Mode”, light bulb or moon icon, upper right.As I first see the new forum design, it's hard to read - the font is small and the contrast against the background is too low. Is htere any way for me to change those?
Thanks!
Dave
Just use your browser’s zoom feature.I can change the font size in this reply. How do you change the whole format to #18?
If I did that, wouldn't it throw off everything else I read online? Take a peek at Beechtalk or for that matter the old VAF for an easy-to-read messsage board in a smaller font. I've tried both dark and light.Just use your browser’s font sizing feature.
Most browsers will remember the zoom level on a per-site basis.If I did that, wouldn't it throw off everything else I read online? Take a peek at Beechtalk or for that matter the old VAF for an easy-to-read messsage board in a smaller font. I've tried both dark and light.
But within the app… not finding a control. Maybe need a default or minimum post / reply font size?Just use your browser’s zoom feature.
I doubt the app supports zoom, you may be relegated to your browser, let is know if you find a way!But within the app… not finding a control. Maybe need a default or minimum post / reply font size?
Please let us adjust the font size!
The font size is too small for my eyes also and dark mode isn't any better. Some of the text areas are a bit lighter, probably for the 'modern' look but not so easy to read.I already adjusted the font size up once, that's about as much as the theme will tolerate without things getting wonky.
There's no facility for a user specified font size, likely because modern browsers let you zoom which is better than adjusting fonts, typically your browser's zoom feature will remember the setting on a per-site basis.
The site has to be mobile and desktop friendly, what's called a "responsive" design, it's the new normal for many years now. However, we just took a 20 year leap into he present.
Curious, seems to work great for me, what browser are you using?I tried zooming but it then pushes some content off the page.
Using Chrome on Samsung tablet.Curious, seems to work great for me, what browser are you using?
+1I can handle the font size but the contrast, or rather lack thereof, drives me crazy. The current graphics obsession with super light grays is annoying. A "clean look" should not trump usability. Specifically I'm objecting to the date stamp and various links and icons. If it's worth putting on the page it should be readable.
Yeah….about that button….I might be doing somethign wrong (quite possibly!), but if it sitting on top of another feature, like “Home” or “Share”, when I hit the back button, it often goes to the other feature. So I have to carefully scroll a bit to make sure the ”Back” button isn’t sitting over somethign else, and then have to wait for it to fade back up to be active….very tedious! Theremust be a simpler way to go “Back” that I am missing….. we got any young people here?There is a back button on the bottom left corner...sometimes is fades in and out.
Doign all this on the iPad of course - should have said that….
THANKS! appreciate all you do to keep us connected.This is on my list of things to look at today, we have limitations that have to be considered, this is a theme that has to be updated with the software updates so things could start breaking. More to consider than just changing a color but we have some options, on it!
I see the improvements, but it still seems the change in color of a "button" when the mouse pointer is hovering over it is still a bit subtle. Thanks for all of this tuning.While I've already previously adjusted the font size a bit I just made some subtle changes to colors in light and dark modes, should help.
