I installed the Jack Points on my RV 7A recently. My left wheel jack point is a very tight fit at the wheel strut and I lack about 1/32" getting the 1/4" bolt aligned enough to slip through the boss assembly. I'm considering drilling out the 1/4" boss hole (assembly bolted to the axle, not the lifting arm) slightly to allow alignment enough to get the bolt through.
The right side Jack point slips through easily. Has anyone experienced this situation with the Jack Points and see slight drilling out of the bore to be an issue with strength for lifting the (roughly) 500# on the left side of my RV 7A?
