ctbecker said:1. I like the idea of using pop rivets to install platenuts. Is there any specific reason they have to be cherry. Since the entire reason for the rivet is only to hold the platenut in place and to resist twisting while installing a screw/bolt it would seem that any (cheap) flush pop rivet would suffice?
2. Somewhere recently I saw some modifications to a floor system that allowed for permanent installation of the flaps and removal of the floor, but I cant find it. HELP.
Broken-wrench said:I scraping the aluminum floor and using the same floor as a comercial airliners fibreglass sandwiched honeycomb with boeing washers for the screw heads, insulation bonded to the bottom
The trick is to cut them. I did it one way:ctbecker said:I'm building an 8A (Slo build) and am having a @#)($* of a time getting the floor panels in. Is there some kind of trick?
