terrykohler
Starting to feel snake-bit. My RV has been pretty much bullet-proof with one exception - tubes. I've had way too many flats over the years (never a problem on my CT210). I've tried different tubes (now using Michelin), had others remount tires for me, gone to and maintain higher pressure (40-45 psi), all without much success. Interestingly, the failures are seldom on the tread side of the tube.
Perhaps it's the wheels??? I can't feel any burrs, but who knows. I've switched tires as well, so the problem isn't likely there.
Can't be over-use, as I'm only flying the plane 100-125 hours per year, and uneven or excessive tire wear is not evident. Brake wear is good.
Has anyone found other wheels to be a fix? Am I alone on this? Suggestions, SWAGS, spitballs, etc. appreciated.
Terry, CFI
RV9A N323TP
Terry, CFI
RV9A N323TP
