The multi stage injection strategies used on most modern diesels are...
...really only used* for combustion noise reduction at light loads and when cold to mitigate the effects of ignition delay. They generally have a detrimental effect on BSFC, so once you're into the mid-part load to full load region, you're back to single injection only. At all the power regimes an aero diesel is using, multiple injection (a.k.a. rate shaping) would not be used.
*also used for dealing with particulate filter regeneration - also not an aero issue.
