On my last few flights I noticed that the last two or three degrees of flaps would not retract until sometime into the flight and not after repeatedly moving the
Flap switch up/neutral/up etc.
I have a TCW flap controller installed and as you can see in the picture, the mechanism relies on a notched rod that indexes the flap positions, 0 degrees, 3 degrees, 10 degrees and 40 degrees.
There is a considerable amount of rotational play on the rod end bearing due to torque generated in the linear actuator. Holding the rod end steady with my finger allows for normal flap retraction.
I cannot tell which part might have worn but the rod end bearing play (side to side) seems excessive and the cause of the issue.
Has anyone seen this problem with their flap actuator?
The rod end bearing could be replaced with one that has less side to side play since the linear actuator geometry does not appear to require a rod end bearing with so much play.
The clamp holding the indexer rod can be rotated and it may be the part that slipped after 800 hours of use? I am thinking of installing a couple of nylon bushings to keep the rod end from excessively rotating. However, that idea seems to defeat the purpose of a rod end bearing.
Any advice is appreciated.
