Group:
Having successfuly bolted my wings on (finally!) I am in the process of rigging the ailerons and flaps.
What is the prefered sequence....Should I get the flaps all situated and rigged to the exension mechanism using the shipping crate airfoil templates, then rig the aileron position to the flaps, or should I do the reverse. Rig the ailerons with the airfoil templates and then set the flaps to the ailerons.
Does it matter which sequence is used, provided you use the airfoil template to rig whatever you are rigging first?
Thanks gang.
Keep the people of the Gulf Coast in your prayers....
Regards,
Thanks gang.
Regards,
