Having resolved my wing installation issue from a couple of weeks ago, I've moved on to installing the flaperon torque tubes where I've run into my next problem: The fit of the torque tube with the F-1261s onto the A-1207-* is so tight that I'm not able to push the torque tube onto the wing tab far enough to make contact with the spacer. I noted when I was epoxying the F-1261s into the flange that the fit was very tight, end it was challenging getting a 1/8" spacer between the blocks, but it seems like the gap closed up after I removed the spacer. It takes a rubber mallet to reinsert the spacers now.
My inclination is to file down the F-1261s slightly until they slide onto the A-1207 tabs with only moderate force, but I wanted to get another opinion before doing something irreversible like that.
Thanks!
Thanks!
