flaperon bearing adjustment
bobnoffs
my right wing is heavy. i have been doing a lot of reading on how to correct it. there have been posts about turning in or out the flaperon bearing into its threaded receptacle . i have a couple questions....was the wing pulled out of the fuselege a couple inches so the flaperon could be disconnected from its linkage and since the inboard most bearing is fixed in its bracket wont moving the flaperon by adjusting mid and outboard bearings put a load on inboard bearing? finally. if mid and outboard bearings are adjusted the same amount won't that ''warp'' the flaperon? the more i read about this the more questions i have.
I purchased my RV-12 from the original builder with 48TT and it had a heavy right wing. I tried squeezing trailing edge of Flaperon and couldn’t discern any improvement. I lengthened / shortened the mid and outboard bearing rod-ends and achieved near perfect lateral balance. Airplane flies with ball centered in cruise flight. Airplane remains in lateral balance with full flap extension. Worked a charm….
I did not keep notes of the actual adjustments, but ended up lengthening on one wing and shortening on the other to minimize the deviation from spec. Wings were not pulled out of the fuselage to make adjustments. Simply remove the hinge pivot bolts and then twist the rod-ends. Have someone support the end of the Flaperon when making adjustment. If I remember correctly, none of the rod-ends were moved more than 1-1/2 turns. It took a few iterations to resolve the wing-heaviness. This work was done early-on and airplane now has > 800TT.
A question…the plans specify Loctite on the rod end threads. Did you Loctite them again? I’m guessing that’s done to prevent thread wear and loosening of the rod ends, since there were no jam nuts. Might be another question for Vans…
I have the exact same problem, and have also tried all of the tricks of squeezing and bumping trailing edges to no avail. I am ready to try the flaperon rod end adjustment. My thought is that lengthening the outboard rod end would add lift. So, if I would lengthen the outboard flaperon eye bolt on the right wing, do you think that would offer more right wing lift and stop the roll to the right?? I was planning to try one full turn ........Tom
thiggins - I did not use add'l Loctite.
todehnal - Try one turn as you suggest. Write down changes you make. Test fly and then add or subtract. I can't tell you which side to lengthen and which side to shorten. Your first test flight will confirm improvement or add'l heaviness. That's why airplane is called experimental...
This may or may not help you, but you might want to verify that the flaperon tubes match the specifications listed on 38iS/U-06. I drilled my flaperons after the rest of the airplane was assembled, so performing this check:
THIS DISTANCE
EQUAL FOR BOTH
ARMS PRIOR TO
MATCH-DRILLING
(STEPS 3 AND 4)
took me a while to figure out. Eventually I settled on using a caliper with an extension arm. I rested the fixed portion of the caliper on the top of the bolt and made sure the flat end of the extension arm was square to the bracket. The delta was 3 thousands. I haven't flown yet (soon), but I was encouraged that the delta here was so small.
OK. I took one turn out on the right end and half a turn out in the center and test flew the airplane. It is a bit windy here today but as close as I can tell, there was little to no roll effect change. What I did notice was that the ball moved right. So I put it back until I can have smoother air to get a good test, or someone else has success with this approach. All that adjusting the length of that rod end does is to raise and lower the outboard end of the flaperon. After returning it to the original settings, I did some very accurate measurements, and to my amazement, both the left and the right flaperons measure almost exactly the same, in reference to the trailing edge of the wings. However, I still have a heavy right wing, even with half fuel and no passenger, as tested today. One more item worth mentioning. At full power, and an 80kt climb, I have very little roll tendency. When I pul back to cruise, the roll right tendency increases, requiring me to hold a little left stick pressure.....Tom
I would contact Vans Aircraft directly and ask them if that’s ok.
I guess a good, and regular check of the security of the rod ends in the pivot brackets would be a great idea too. Turning them like we’re talking about here breaks the bond that the specified Loctite made at initial assembly. There’s probably a good reason they specify it.
:rolleyes:
sooooo .......those who have adjusted the bearings are able to do it without sliding the wings out from the fuselege a couple inches?
Adjusting is simple. Remove the center and outboard bolts, slip the rod end out of the bracket and slide it back in after making your adjustment, then reinsert the bolts. Takes 5 minutes.
Loctite!
I would modify this process to include new Loctite per the approved KAIs from Vans. That’s what I will do if I decide to go that route. Not doing so could be dangerous (there I said it).
:eek:
Per my posts above... I should further clarify that in climb I need to add ~ 3 lbs force on right rudder to center ball. Conversely, in a glide, a slight amount of left rudder is required. Ball is centered with feet on the floor in cruise flight. This indicates the the plane is nicely rigged for cruise. Right rudder in climb is need to offset torque and P-factor, as it should be. And in a glide, with engine making no torque, left rudder is needed to compensate.
I love this airplane - 800 hours in 7 years....
