EchoJuliet
Member
Model RV-12iS, dual Dynon Skyview HDX; I have a situation where on the initial deployment of the flaps on a runup check, the flap position indicator will not move for 2-3 seconds and then it will catch up to the correct flap position. It only does this for the one time and then behaves normally for the rest of the flight. Yes, I've recalibrated the flap settings to see if that was the issue. Any ideas?
