Paris12Man
Hello All,
Has anyone had any issues with the "slot" in the flap handle not being exactyly in the right spot in regards with the Detent Bracket? Even without the spring and fork assembly being inserted in the flap handle, the detent bracket hangs up on the slot and is not allowed to freely move in and out....hope that makes sense. I believe I will have to lengthen the slot about 3/8" to allow free movement but kind of nervous in making the cut. In order for mine to work properly now, I have to place 2 washers under the rear screws to place the detent bracket at a different angle and thus move in and out through the slot.
Does anyone have any pictures showing how the bracket and slot are suppose to align.
Thank you for your help.
